I need to change the Tsplus logo on application panel and floating panel and did not find any option to change it from admin tools.
Thanks,
Change the Logo on application panel and floating panel
Re: Change the Logo on application panel and floating panel
In the current version of TSplus, you can customize the logo. Open an admin tool, click on the application tile, then customize floating panel, and then under Customize the floating panel logo, click select to import your own logo. (must be a .bmp 122x74)
