Active Directory Integration
I have downloaded the demo TSPlus software and installed it on a Windows Server 2016 box. The server it is installed on is part of a domain and there is another server on that domain that is running the AD services. When I go into the Admin Panel for TSPlus and try to add users it is only seeing the local accounts on the server that TSPlus is installed on. How do I get it to see the AD server and accounts that have been setup on that box? Based on the info I see on the TSPlus website, it should be able to integrate with AD, but I can't figure out how.
Re: Active Directory Integration
You need to make sure your TSplus server has successfully joined the domain. Then log in as a domain administrator, once you will assign an application you will be able to see the list of domain groups and users.
This action may take a few minutes if your domain is large.
