Mac with non-HTML
anupmistry
Mac with non-HTML
With the 'Printer Edition' sku of TSPlus, can we publish app and view on an Apple Mac? How about iPad or Android? Will it say work with the JumpDesktop app from the MacStore.
anupmistry
Re: Mac with non-HTML
If supported on a Mac, how would the printing work? Only supported printer would be the Universal Printer. Was looking at Print2RDP works on windows does not on Mac. Does TSPlus recommend such an addon for the Apple Mac?
You will be able to connect and print using the Universal Printer by connecting using HTML5.
You can also connect using the RDP client for mac available on itune, printer redirection is also possible in this case.
anupmistry
But the 'Printer Edition' of TSPlus does not have HTML5. So we would have to buy the TSPlus. 'Mobile Edition'. Correct?admin wrote:You will be able to connect and print using the Universal Printer by connecting using HTML5.
Yes, the Universal Printer is only supported with HTML5 if you plan on connecting from a Mac. Now if you can test the RDP client for mac and print using standard printer redirection maybe a system edition will suffice in your case.
