Good evening, I just installed your demo on my server.
I claim that I use a server that has no rdp previously installed.
On reboot no longer accepts the administrator password and then I can not access the server again !!!
What should I do???
New installation on win server 2008 r2
Re: New installation on win server 2008 r2
Did you install the active directory role on your server ? If so, type in your domain name in capital letter followed by a \ sign and the name of your admin account, it should look like this :
username field
MYDOMAIN\Administrator
If you did not install the active directory role, use the hostname of your server instead.
username field
Thanks problem solved ... I did not realize I accessed the machine name \ administrator ....
Thanks again
Thanks again
