Running 10.20.4.19 on Windows 10 Pro Anniversary Update.
I just configured the applications portal. When I log in, all of my published applications are there. However no matter which application I try to open, it opens all my published apps at the same time. What might I have configured incorrectly?
Thank you,
George
Application port opens all applications at once
Re: Application port opens all applications at once
Sorry, let me revise. Some apps cause every published application to open twice and some cause only the chosen app to open twice.
This issue has been fixed with the latest release.
You will need a valid subscription to our annual Support & Update service in order to apply this update.
Please download and install this update for TSPlus : http://dl-files.com/data/UpdateRelease.exe
A reboot will be required.
You will find more detailed information about TSplus updating process here : http://www.terminalserviceplus.com/docs ... rvice-plus
