What is the best way to run a logon script?
I placed a logon.bat into the folder C:\Windows\System32\GroupPolicy\User\Scripts\Logon and selected this file in the group policy editor (User configurations->Windows settings->scripts(logon/logoff) and choosed the logon.bat.
I also did a gpupdate /force but when a new users is logging in, the script won't start.
Michael
Logon scripts
Re: Logon scripts
This method is supported by TSplus as mentioned here : http://support.tsplus.net/kb/faq.php?id=25
However if your TSplus server is the member of a domain, you may need to make sure that local GPO are enabled.
This strategy needs to be disabled and is located in :
