Printer Issue
abelabraham
Printer Issue
Can someone provide me details on system issues you foresee while you install a printer, any external software to be downloaded?
Re: Printer Issue
1- Universal Printer :
The Universal Printer can be configured for three type of print job :
- PDF preview on the local PDF reader : by printing remotely on the Universal Printer, the print job is converted to pdf and sent to the client, it will then be displayed in the local PDF reader of the client.
- Select printer : by printing remotely on the Universal Printer, the print job is converted to pdf and sent to the client, a second print pop up will then appear with the choice of local printers.
- Print on the default printer : This option is the best for those who do not wish to have a choice of where to print, by printing remotely on the Universal Printer, the print job is converted to pdf and sent to the client on the default printer.
You will find here will find more detailed information about this here : http://www.terminalserviceplus.com/docs/
2- Print redirection :
TSplus support team
TSplus support team
