As TSP changes versions, how often we should re-generate new clients? Can client exe be from version 7.x and TSP server with version 9.x?
When replacing client on customer computer, should we delete RDP6 folder or it is unnecessary?
Client generation
Re: Client generation
Generating a new connection client is necessary when you update from a 8.xx version or below to a 9.xx version as well as delete the RDP6 folder. Connection will still work, but features like Universal printer / file transfer and load balancing will not work.
You can also use this procedure to delete the RDP6 folder : http://www.terminalserviceplus.com/docs ... ted-client
