Translation of HTML5 toolbar.
AadGouka
Post by AadGouka » Wed Jul 13, 2016 10:56 am
Is there a way to translate the messages and window names of the HTML5 upload/download toolbar into another language ?
I noticed some possibilities in the Language.js, but these are not sufficient.
Best regards,
Aad Gouka
juwagn
Re: Translation of HTML5 toolbar.
Post by juwagn » Wed Jul 13, 2016 3:34 pm
Can you be please more specific, what messages are not inside language.js?
Inside session/inside browser, which one?
Upload/download pages are located in
www\software\html5\own\getlist.html
www\software\html5\own\getupload.html
AadGouka
Post by AadGouka » Wed Jul 13, 2016 7:17 pm
I.e. downloading a file the window says "Select one remote file to be transferred from server->to your local PC" or
when I leave this screen without downloading "No file selected. Do you want to exit ? "
In the OWN map I see some texting that can be translated indeed.
Best regards,
Aad Gouka
juwagn
Post by juwagn » Thu Jul 14, 2016 2:30 am
or
The reason why you can not change these strings is, that is not webinterface, but program running inside rdp session.
Even if it is called from browser side, it is still windows program and unfortunatelly out of my control.
I hope others can help you.
AadGouka
Post by AadGouka » Thu Jul 14, 2016 9:43 am
Ok, thank you very much for your explanation.
Best regards,
Aad Gouka
Post by admin » Thu Jul 14, 2016 3:22 pm
After studying this subject it appears that you can edit with notepad the languk.ini file located in C:\Program Files (x86)\TSplus\UserDesktop\files
press ctrl + F to search for the string of characters you are looking for and save. The change will be effective at next logon.
I recommend you to backup this file before modifying it for safety.
AadGouka
Post by AadGouka » Fri Jul 15, 2016 9:23 am
Thank you for answer. Just to be on the safeside, maybe it's easier to rename the languk to langdu or
will this interfere with other modules.
Thanks so far.
Best regards,
Aad Gouka
Post by admin » Fri Jul 15, 2016 3:01 pm
Simply copy the original file in the same folder and rename it langukORIGINAL.ini, this way you have it for your reference in case you save some mistake.
