TSPlus with Direct3D application?
ecsw
Post by ecsw » Thu Apr 28, 2016 4:22 am
I am planning on setting up a workstation with powerful video card to share some rendering/CAD/Direct 3D from the workstation with TSPlus.
TSPlus works great on most software, but when trying to run some Direct3D applications, it fails. Is Direct 3D through TSPlus supported like RemoteFX on Windows Server? If so, how should I change the settings so it will pass the Direct 3D GPU rendering over to clients side?
Any help is appreciated.
Re: TSPlus with Direct3D application?
Post by admin » Thu Apr 28, 2016 10:03 am
Unfortunately unless you find a specific procedure for installing your software on a RDS environment this will not be supported by TSplus, sorry for the bad news.
