Seamless Client Setup
geedee
Post by geedee » Wed Apr 13, 2016 4:16 am
Hello all
Can some please confirm if the Windows Client Generator will no longer correctly create the "Seamless Client"?
I had advice that it was getting dropped yet it is in the latest version still.
Am I just banging my head against the wall trying to get this to work?!
RemoteApp will only create a communication and connect. Seamless launches and just pings a sound and does nothing else...
Anyone?
Sean
Re: Seamless Client Setup
Post by admin » Wed Apr 13, 2016 9:04 am
Seamless and RemoteApp connection client serve only one purpose : to display a remote single application as if it was installed locally. This is why you should never assign a full remote desktop to users who uses this connection method.
You are also correct, we used to remove the seamless connection client because it was not supported anymore on Windows 10. As for the RemoteApp, it is not supported on older operating systems such as Windows XP / 2003, this is why we kept both connection options.
More information about these connection client can be found here : http://www.terminalserviceplus.com/docs ... ion-client
geedee
Post by geedee » Fri Apr 15, 2016 1:15 am
Thank you Olivier
Appreciate the clarification!
