The built-in HTTP Server is not listening on port xx
After I reboot my server, I found this problem is appear. how to fix it?
Before reboot my server, everything is working well.
Re: The built-in HTTP Server is not listening on port xx
Have you tried restarting your web services manually ? Possibly the port 82 may be already in use, you can verify this information with the netstat -na command, in which case switching to a different port will solve this issue.
Hello Sir,
I tried to restarting web service, server so many times already. It's not working well.
And the port 82 must not be using in whole network too. Please find my "netstat -na" result as below:
Active Connections
Proto Local Address Foreign Address State
TCP 0.0.0.0:135 0.0.0.0:0 LISTENING
TCP 0.0.0.0:445 0.0.0.0:0 LISTENING
TCP 0.0.0.0:2638 0.0.0.0:0 LISTENING
TCP 0.0.0.0:3391 0.0.0.0:0 LISTENING
TCP 0.0.0.0:6203 0.0.0.0:0 LISTENING
TCP 0.0.0.0:6247 0.0.0.0:0 LISTENING
TCP 0.0.0.0:19955 0.0.0.0:0 LISTENING
TCP 0.0.0.0:47001 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49152 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49153 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49154 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49155 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49163 0.0.0.0:0 LISTENING
TCP 0.0.0.0:49164 0.0.0.0:0 LISTENING
TCP 127.0.0.1:2638 0.0.0.0:0 LISTENING
TCP 127.0.0.1:5939 0.0.0.0:0 LISTENING
TCP 127.0.0.1:5939 127.0.0.1:49161 ESTABLISHED
TCP 127.0.0.1:49161 127.0.0.1:5939 ESTABLISHED
TCP 192.168.0.96:139 0.0.0.0:0 LISTENING
TCP 192.168.0.96:49185 217.146.1.42:5938 ESTABLISHED
TCP [::]:135 [::]:0 LISTENING
TCP [::]:445 [::]:0 LISTENING
TCP [::]:2638 [::]:0 LISTENING
TCP [::]:3391 [::]:0 LISTENING
TCP [::]:19955 [::]:0 LISTENING
TCP [::]:47001 [::]:0 LISTENING
TCP [::]:49152 [::]:0 LISTENING
TCP [::]:49153 [::]:0 LISTENING
TCP [::]:49154 [::]:0 LISTENING
TCP [::]:49155 [::]:0 LISTENING
TCP [::]:49163 [::]:0 LISTENING
TCP [::]:49164 [::]:0 LISTENING
TCP [::1]:2638 [::]:0 LISTENING
UDP 0.0.0.0:500 *:*
UDP 0.0.0.0:4500 *:*
UDP 0.0.0.0:5355 *:*
UDP 127.0.0.1:2638 *:*
UDP 192.168.0.96:137 *:*
UDP 192.168.0.96:138 *:*
UDP 192.168.0.96:2638 *:*
UDP [::]:500 *:*
UDP [::]:4500 *:*
UDP [::]:5355 *:*
Active Connections
UDP 0.0.0.0:500 *:*
UDP [::]:500 *:*
UDP [::]:4500 *:*
UDP [::]:5355 *:*
Have you tried connecting with HTTPS://yourserver.com:445 ?
Uninstall java and delete the java folder located in C:\Program Files x86\ and C:\ProgramData (this is a hidden folder) then reinstall java 64 bits on the server. Once this is done, restart your web service again.
Hello, test with https://127.0.0.1:445, it's fail again.
And then, I was re-install the java 64bits on my server. Then, restart the whole server again. I got the same problem.
This means another application is conflicting TSplus web server. Have you reinstalled Java as suggested ? Could you try with a different set of port ?
You need also to check that the BrandCache service is disabled as it is not compatible with TSplus web services.
Hello Sir,
- Yes, I was reinstall the Java already. My Java version is show on attached picture.
- I tried the orginial port 80 already, the problem is same.
- My windows did not install the BrandCache Service.
Problem Solved. Thanks!
Solved? How...would be interested to know as I am a Newb with the same problem!
edit: Solved for me with the Java reinstall 64bit. Thx Olivier!
Please let me know how do you solved, I have the same problem
