I couldn't find an answer in the FAQs/Forum to my question so I thought I try it here: I wanted to know if there is the possibility to start a RemoteApp Application directly without the "Start menu" which gets started by the seamless client. I tried to rewrite an existing TerminalServer RDP file but I only get that the application couldn't be found. Is there a way that the Application gets started directly? May or may not the password/login information be saved. So the user could start the RemoteApp like any other application. The additional start menu is somehow confusing for the employees.
Thanks for your help.
RemoteApp
Re: RemoteApp
Opening a unique application in RemoteApp or Seamless mode is one of the basic feature of TSplus.
I recommend you to watch this video to get you started with TSplus : terminalserviceplus.com/videos/start-your-remote-desktop-solution.php
You will find here a documentation on how to publish new applications : terminalserviceplus.com/docs/application-publishing
And how to assign these applications to users : terminalserviceplus.com/docs/assigning-applications-to-users-or-groups
Re: RemoteApp
Well after looking threw it and what I experienced with my demo setup I'm missing the option to choose what to start within the client generator. If only one application is assigned it will start it, if RemoteDesktop is assigned it will start this and if multiple Apps are assigned it will start the menu. But my needs would be the possibility for 2 Apps to be able to started each whenever needed and also Remotedesktop if outofoffice.
Has anyone experienced similar needs and found a solution?
Re: RemoteApp
If you assign two applications to a single user or group, these two applications will start at logon.
If you do not wish for these applications to start automatically, then you should consider assign also the floating panel or remote taskbar to this user/group.
More information about this feature can be found here : http://www.terminalserviceplus.com/docs ... ting-panel
