Gernerated Client: How to remove TSPlus Logo?
- bytemasters
- Contact:
When printing with the generated client, a Tsplus logo pops up at the left-top corner. How can i configure or disable this?
Kind Regards
Michael
Michael
Re: Gernerated Client: How to remove TSPlus Logo?
I am sorry but this logo cannot be customized.
- bytemasters
- Contact:
I found a similar software named "TSspeedbooster", I doubt they could change the TSplus logo.
You could follow below link .
https://www.youtube.com/watch?v=sTtG6UlIMmI
Rgds,
ARun
Rgds,
ARun
TSspeedbooster is TSplus under a different label
Hi Admin,
Thanks for the prompt reply. I have installed TSspeedbooster (Trail Version), but the license version is little bit expensive than TSplus. Shall i buy TSplus license and activate TSspeedbooster, or do i need to unstall TSspeedbooster and install TSplus to activate the license.
Rgds,
Arun
Rgds,
Arun
It is the same licensing system, however you can also uninstall TSspeedbooster, reboot and reinstall TSplus if you like.
