HTML5 Client - Floating panel
dave
Post by dave » Tue Aug 04, 2015 8:46 pm
We are currently only using/allowing connections to our TSPlus server via the HTML5 client. Is there any way I can configure the server so that when a user logs in, their Windows session is loaded and they see the 'floating panel'. With the current configuration they can see the application portal with all the applications they have access to listed. They then click/tap on the floating panel and wait for it load. I think would prefer that floating panel loads right away, then they can choose their application from it. Thanks!
dave
Re: HTML5 Client - Floating panel
Post by dave » Tue Aug 04, 2015 10:27 pm
I think I just figured out my own question. I turned off the 'applications portal' and now the Windows session loads right away (as I was hoping it would).
