Hi!
Can I restrict access to the server over the time?
Time access to the server
Re: Time access to the server
Open an admin tool, go to the security tile, and click on "Server advanced security options"
You can choose to check the "Block all incoming access to this server" box to prevent any user to login. This security rule is applied immediately, be warned that if your server is hosted in a datacenter, even you will not be able to access it anymore unless your are already connected.
Thanks!
It would be nice to automate this function.
