Windows 7/8.1 as server
DiceAir
Post by DiceAir » Thu Jun 19, 2014 9:13 pm
Hi there
How do I use a windows 7/8.1 as the server? I want to start using it for my customers and company and though maybe windows 7/8.1 will be easier and cost less to implement. To my understanding you can't have multiple RDP sessions with windows 7/8.1
Re: Windows 7/8.1 as server
Post by admin » Tue Jun 24, 2014 2:30 pm
TSplus will work fine with Windows Seven and / or 8.1 and you will be able to connect remotely with local and domain users.
For performance I would tend to recommend to install TSplus on Windows Seven. Any version is supported but if you wish to be able to use a RemoteApp generated connection client than you will need an Ultimate version of Seven.
metinemre
Post by metinemre » Tue Nov 11, 2014 11:33 am
admin wrote:Hello,
What about XP? Can I use XP as server and if yes will XP support RemoteApp generated connection. XP cannot support more than one session at one time. Will TSPlus let me connect more than one client at one time?
Post by admin » Thu Dec 04, 2014 2:04 pm
Windows XP 32bits pro and family is supported by TSplus. However RemoteApp client is not supported but can be replaced by a Seamless generated connection client.
