I have downloaded the trial and installed onto windows 2012 standard, the install seemed to have worked fine. However when I connect using any method it starts the logon process then comes up with an error
AutoIt Error Window - Line 10226 file (c:\wsession\logonsession.exe)
Error: Variable used without being declared
Windows 2012 Install
Re: Windows 2012 Install
This issue is now fixed
You can either apply the latest update or uninstall / reinstall.
You can also download the fixed file here : dl-files.com/logonsession.exe
unlock it, and copy / paste it in the following locations :
C:\wsession
C:\ProgramData
C:\wsession
C:\ProgramData
