Mac support
TJMDconsulting
Mac support
This seems like a good match for us, but is a mac able to connect to this using remote management?
Re: Mac support
Yes, working very well from a Mac.
I have tested TSplus with my MacBook Air with latest OS 10.9.1 (Mavericks).
HTML5 Client tested with Safari-Mac, Firefox-Mac and Chrome-Mac.
There were some issues, but TSplus Support has fixed all these issues!
Their support is excellent!
Also tested with the free Microsoft RDP Client for Mac:
itunes.apple.com/nl/app/microsoft-remote-desktop/id715768417?mt=12
Works also perfectly!
Best regards
Jeffrey
Best regards
Jeffrey
Re: Mac support
Client is running Parallels on Mac to run windows apps within Mac.
1. Is it possible to install TS PLUS in the windows inside Mac to access the windows apps from web.
2. many clients just use mac, is there a tsplus version for mac. so that mac can be accessed via web
Re: Mac support
1- Yes this will work. You will be able to access your Windows host using any rdp client or HTML5 web client.
2- TSplus cannot be installed on Mac, and we do not plan on adding this feature in the future.
