Upgrading from 4.9.x to current
johnmani
Post by johnmani » Wed Dec 11, 2013 7:44 pm
Can I run the updaterelease.exe when upgrading from 4.x to 6.x? Or do I have to install 5. releases first?
John
Re: Upgrading from 4.9.x to current
Post by admin » Wed Dec 18, 2013 8:48 pm
Yes you can use the update release to upgrade from 4.x to latest.
A reboot will be required as well as a regeneration of your connection clients.
johnmani
Post by johnmani » Mon Jan 13, 2014 7:00 pm
Thanks for the response, sorry it took so long to reply I went on vacation.
John
