Hallo Support,
Welche Einstellungen müssen wo vorgenommen werden, damit der Drucker für MacOS unterstützt wird und vom Server aus genutzt werden kann?
Gibt es einen TSPlus Client für MacOS?
Drucker für MacOS
Re: Drucker für MacOS
My recommendation is to use the RDP client for MAC, available on Microsoft website. You can also use TSweb features that includes HTML5 or Java client to remotely connect and print on your MAC.
TSplus support team
TSplus support team
I have the same problem I have a user with a MacBook Pro that needs to be able to use the universal printing feature.
Is there any sign of a client for this? Or a workaround?
Graeme
Graeme
You can use TSplus HTML5 client and/or TSplus JAVA client to connect from a MacBook Pro.
These two clients include the universal printing feature.
Kind regards,
TSplus support team
Kind regards,
TSplus support team
Sorry to bring up on old thread... but is there any plans for building a universal print feature for the MAC? Unfortunately I cannot use the web for my clients - so no HTML5 client or Java will work for me
