I am trying to get TsPlus to print on the client machine. Have tried checking: Print on Default Printer -- in Client Connection. Also tried: Select Default Printer. No luck.
The docs say that you need to include default printer when creating a client. How or where is this done?
TsPlus version 6.10. Server is Windows 2003, Client is XP and Windows 8.
Thank you.
How to Set Up Printer
Re: How to Set Up Printer
Same problem here, except that default printer works for few days. Not any more...
If the Universal printer has worked before try deleting the RDP6 folder in Appdata/Roaming folders this is where temp files are stored on the local machine, its resolved the issue for us many months ago. A new RDP6 folder will be created next time you connect.
Al
Al
