I have another question about seamless application. When i use a seamless client created by ClientGenerator i can run seamless application and i dont get the desktop. But i use RDP and logon to server i get full screen window of an empty desktop and then the application. How i can i run seamless application using RDP? but without using tool created by Clientgenerator?
Kind regards
Seamless vs RDP
Re: Seamless vs RDP
If you want to use the remote taskbar in an rdp session you need to assign it using the admintool.
If you do not want to see the TSplus taskbar, you must assign the application named "Microsoft Remote Desktop" to your users.
regards,
Paul
regards,
Paul
Re: Seamless vs RDP
I think the answer is that there isn't a way to use seemless unless the client generator is used. Correct?
Re: Seamless vs RDP
Seamless can be used using the client generator or TSweb by selecting the "Application outside your web browser".
TSplus support team
TSplus support team
