i updates several TSplus servers to the newest 12.30.6.13 and now my Web Poral login forms are broken:
- only the user field and the login button are available, so no login is possible
Can you please check this immediately?
Michael
12.30.6.13 - Web Login broken!
Re: 12.30.6.13 - Web Login broken!
ok, found a fix:
goto TSplus Admin -> Web Portal -> Web Portal Design and just click save. Reload the Web Portal in your browser and the login form is ok again...
nevertheless - please check this update.
Michael
Michael
we have the same problem.
Your solution works!
Thank you
Thank you
Thank you for your feedback and workaround, a fix is available now. It is version 12.30.6.14
