Session support
Session support
Hello
I asked days ago and can't find my question in the forum, so I will ask again: I'm looking for a support solution that enables a person to "capture" the session of anyone who wants support and allows it (as we do in softwares like TeamViewer), however I'm looking for something that runs directly from the server without the need to install any software on client stations, I use many credentials for same windows user. I wish to provide my resellers a way to perform session support for their clients.
Thanks for your attention.
Re: Session support
We use simple help as our support system. We provide in session support
Re: Session support
Hello
What you mean ? it's a resource to activate ?
Re: Session support
I'm refering to a support service like we have when using Teamviewer, capturing session to see it in my screen and the user keeps loged in following while I do, just intalling additional software on the server, not stations. How exactly do you do ?
Re: Session support
we use Simple help
We run if from our server for our customers and resellers
a client install is done once per rdp server we our resellers or end customers IT can then enter an rdp session and help the logged on user if they get stuck or need assistance
We provide a slimmed or very slimmed down version for resellers and end customers IT, you create the required version in Simple Help
Once installed on the server it just runs and we have unattended access to the server or session whenever required
https://simple-help.com/provider
Re: Session support
Simple help looks nice. For your information, RDS Knight now provides also protection for VNC products, and we use Supremo software for remote control of TSplus servers for troubleshooting purposes. No installation needed, you execute the client and that's it. Check it out here : https://www.supremocontrol.com/
Re: Session support
vivburrows wrote: ↑Fri Nov 16, 2018 8:57 pmwe use Simple help
Re: Session support
Hello
I was looking for a way to retrieve HTML5 session (frames) of the client station to support session, without any installation, to exchange files, texting and record video of the support session at the end. Essentially, Screen sharing a browser tab in HTML5 with the ability to interact with it like I was local user. I can share the browser tab (by using Rafael Weinstein mutation observers), but it's pretty hard to implement the interaction (and send it back to client), and I don't have the time for this.
admin wrote: ↑Fri Nov 16, 2018 10:25 pmHello,
