I noticed that by using the /verysilent parameter with the newest installer, that RDS Knight Trial gets automatically installed (it normally prompts after install).
How long does that trial last?
(EDIT: I've seen in RDS-Knight UI that it's 15 days)
When the trial expires, will a popup appear after every reboot or every session reminding to activate it?
(EDIT: I played around with the date in a test system, and a message would only pop up if I opened RDS-Knight)
If the second question is a yes, is there a parameter for the installer to not activate the RDS Knight Trial?
(EDIT: Since no message pops up, I would not care about getting an answer for this, unless you guys see an issue somewhere)
Thank you and kind regards
TSplus 11.50 Silent Install
Re: TSplus 11.50 Silent Install
Yes this is possible by adding the /Addons no switch.
example :
`Setup-TSplus.exe /Addons no` or `Setup-TSplus.exe /VERYSILENT /SP- /SUPPRESSMSGBOXES /NORESTART /Addons no`
example :
