Apologies if this has been covered before - I couldn't find it.
Is it possible to configure TSPlus to allow persistent user sessions? That is, if a user logs in, does some work, disconnects and reconnects, their session is still open and any applications or documents they had open previously are still there? It appears that TSPlus automatically signs a user out after they disconnect, which is extremely painful if you have an intermittent signal or your tablet locks you out from inactivity or similar.
Thanks,
Trevor
Persistent User Sessions?
Re: Persistent User Sessions?
Hello? Is this not possible with TSPlus?
Yes this is possible !
Check the "Allow users reconnection when sessions are disconnected."
Check also the "Allow automatic reconnections when a session is disconnected."
You can also set up a timeout for disconnected sessions which will cause a disconnected user session to automatically logoff after a while.
If you are experiencing this issue with the HTML5 web client, edit the settings.js file with notepad located in C:\Program Files (x86)\TSplus\Clients\www\software\html5
And modify the W.send_logoff = true parameter to false.
Thank you, that's very helpful.
