Publishing Folders to Floating Panel
Works quite well with folder.exe but every time I try and drag or drop I get a "Windows Security" pop-up on my computer to the effect "Do you want to allow files from this website to run on your computer?". My computer is a Windows 10 Professional. Any way to get rid of this annoring pop-up?
Re: Publishing Folders to Floating Panel
Have you tried removing the UAC ?
This is done in the control panel / manage user account or you can disable it for all users in the admin tool / security tile / advanced security tile.
