Silent Install + Import Settings + Activate License
strajk
Post by strajk » Tue Oct 10, 2017 7:03 am
by searching the Forum I found out that there is the neat feature of performing a silent install by using the parameters /silent (shows dosboxes and restart prompt) and /verysilent (shows nothing), there is also /norestart so that the Installation does not automatically restart by itself in case the prompt is hidden with verysilent.
What would be interesting to know, if there is a command line parameter to import configurations that were exported (C:\Backupparam) with the "Restore Server Parameter" feature, and if there is also a command line parameter to activate the license.
End goal is to prevent the user to see any kind of Installation and Configuration mask, to only use whatever we provide in our own installer that already has a fix set of configurations, because we want to avoid the risk of them going into the Admin Tool and configure stuff incorrectly, so making a foolproof installation of our environment is our goal.
Also, is there a page or documentation that has all possible parameters?
Would be really interesting knowing how much we can tweak the installation.
As always, thanks for the great help.
strajk
Re: Silent Install + Import Settings + Activate License
Post by strajk » Thu Oct 12, 2017 8:59 am
Found out that /? is a thing, it basically outputs the content of the following link:
http://www.jrsoftware.org/ishelp/index. ... tupcmdline
So I guess there are no custom Parameters to actually import settings and activate the license?
Or an App of yours that gets installed that support some kind of parameter to do one or both of those?
Robson
Post by Robson » Mon Nov 27, 2017 9:17 am
strajk wrote:Found out that /? is a thing, it basically outputs the content of the following link:
Thanks for the link! Got it working.
kepadar
Post by kepadar » Mon Mar 26, 2018 10:09 pm
Yes, thanks a lot! Very helpful link
This forum is really amazing! Only here I have found online mobile casino no deposit bonus. Thanks to every member here!
