There is an icon called "Server Roles" in the License section of the admin tool. What is the difference between "Multi-Session" and Windows RDS role? Why would you choose one over the other?
Simon
Server Roles under the License Section of Admin Tool
Re: Server Roles under the License Section of Admin Tool
This feature is to be used only when you install TSplus on a server which already has RDS role activated with active RDS cals. It allows you to switch from TSplus licensing mode to RDS licensing mode.
I tend not to recommend to install TSplus on a RDS server as it can lead to port conflict with TSplus.
Thank-you for the explanation.
Simon
Simon
