TSplus Farm
TSplus Farm
I am looking to setup a farm with multiple servers. How can I see all logged in users across all systems, and logoff if needed?
Damian C. Stalls
Senior IT Engineer
Senior IT Engineer
Re: TSplus Farm
As for now the only way of monitoring logged on users is to open a task manager on each server of the farm. Doing so you'll be able to manage your users and logging them off or sending them a message.
Re: TSplus Farm
Is there any on-going development on this?
a central app that can be run to monitor users across multiple Terminal Servers from a single pane of glass.
I have been using Smart-X Control-Up for a Microsoft TS Farm, and are looking for similar functionality with TSPlus if possible before purchase.
Cheers.
Cheers.
Re: TSplus Farm
Yes this is one of the many features we plan on implementing in the future, I cannot tell you when this will be ready thought.
