I am a software developer, and I want to set up MY CLIENT with an application I have developed, using TSPLUS.
I have purchased a 5 user system at this time.
The TSPLUS will be installed on my client's server
I also want to set up another client with either the same or a different application.
Again, TSPLUS will be installed on their server.
What is the best way to do so as far as TSPLUS is concerned.
i.e. should I buy another 5 or 10 (or whatever) TSPLUS system, or do I simply buy more licences
licencing
Re: licencing
A TSPlus license is valid for one server, thus you will simply need to buy a new license (such as a 5 user System edition) for the new server.
Re: licencing
OK, I understand. Its simple
However, 15 days wasn't quite enough to complete my testing.
I have purchased a 5 user system. Can I use the licence number on my personal server and when ready, transfer it to my client's server?
Re: licencing
If you uninstall TSplus from your personnal server, then yes, we can do a "rehost" for you.
Please contact our support team at http://tsplus.net/support/
