Just wondering if I install TSPlus on a client OS (XP, 7 or 8), does it have the same restrictions as the client share restrictions (can only support 10 concurrent connections)?
The application I want to share, only installs on client OS's, so there is no use buying a license for 50 connections if it can only handle 10.
Client OS (XP, 7 or 8)
Re: Client OS (XP, 7 or 8)
No, it will not be restricted.
With TSplus you can open 50 concurrent session without restriction.
The restriction is on device access. For example is you use IIS, Windows is restricted, but our built-in web server does not have restrictions.
If your application required shared folder, or is a data base application using Net USE, the restriction will apply too.
Kind regards
John Davies
logo
Kind regards
John Davies
logo
