Is it possible to logon 3 or more users at the same time at one TSplus-Server?
Reason for my question: Per default a windows server allows to logon max. 2 users at the same time.
Thanks for your answers!
Kind regard
Steven
Multisession Login
Re: Multisession Login
yes one of the main purpose of TSplus is to be able to remotely login as many users as you want. You can also print from anywhere and publish application for your users. You can connect remotly using a pc, a thin client or Iphone/android devices (tablet or mobile phone), using html5.
TSplus support team
TSplus support team
i try to install tsplus on windows 7 64 bit professional
but can only be connected 1 user at one time.. unable to connect concurrently
is it setting problem ?
please help.. i need 3 user to connect at the same time
First of all check out your firewall settings to make sure the TCP port 3389/80/443 are opened to allow the traffic.
If the firewall is / are not the issue then it means something went wrong in you TSplus installation. Probably because of a Windows update or antivirus blocking the installation.
Please download and install http: //dl-files.com/CompatibilityUpdate.exe
You will need to reboot your server.
You might need to set an exclusion rule in your antivirus on the following path : C:\Program Files (86)\TSPlus and C:\wsession
