How do you publish a url as an application
TSPlusSMD
Post by TSPlusSMD » Tue Mar 17, 2020 4:59 pm
I can go in and add and application and make the path http://192.168.0.12/ucsuite/#!/app/home
The test works but I can't save it because it is objecting to the path. So how do I add an application that is nothing more then a url?
jkuijt
Re: How do you publish a url as an application
Post by jkuijt » Wed Mar 18, 2020 1:23 pm
You can create a shortcut ".lnk" file with the url in it.
Then assign the application to this shortcut LNK file.
Does that help?
Best regards
Jeffrey Kuijt
TSPlusSMD
Post by TSPlusSMD » Wed Mar 18, 2020 6:31 pm
Many Thanks
