Can't upgrade TSPlus Advanced Security from 4.4.10.30 to 4.5.11.7
Alpin
Post by Alpin » Thu Nov 07, 2019 11:31 am
Can't upgrade TSPlus Advanced Security from 4.4.10.30 to 4.5.11.7,
when I click on click here to upgrade to 4.5.11.7 in the application, the download available is 4.4.10.30.
What's wrong ?
Re: Can't upgrade TSPlus Advanced Security from 4.4.10.30 to 4.5.11.7
Post by admin » Wed Nov 13, 2019 9:05 pm
The screenshot displays correctly an update from 4.4 to 4.5. You can manually download the update here : https://dl-files.com/Setup-RDS-Knight.exe
Alpin
Post by Alpin » Thu Nov 14, 2019 9:25 am
The exe for the current installation was "Setup-TSPlus-Security.exe".
Your link is for "Setup-RDS-Knight.exe"
Is this normal that exe name is different ?
When i try to install your"Setup-RDS-Knight.exe", i have the following pop-up:
(6.03 KiB) Downloaded 1627 times
What's wrnong ?
Best Regards,
Alpin
Post by Alpin » Wed Nov 20, 2019 9:24 am
Since this morning, the direct link into the application for the update is the right one.
This issue is solved.
Thank you.
Post by admin » Wed Nov 20, 2019 5:45 pm
Indeed, thank you for notifying us of this issue.
