Target RDP server not accessible!<br />127.0.0.1:3389
bzdega
Post by bzdega » Fri Jun 14, 2019 11:21 am
on one of my TSplus-Servers i get this error when connecting via Windows client or web client.
This is an issue which pops up from time to time.
What can cause this error?
Michael
bzdega
Re: Target RDP server not accessible!<br />127.0.0.1:3389
Post by bzdega » Fri Jun 14, 2019 1:30 pm
I think i know what i made wrong:
I placed this GPO (mentioned in an other thread) within the domain GPOs, not in the local GPOs on the TSplus server:
  • Computer Configuration > Administrative Templates > Windows Components > Remote Desktop Services > Remote Desktop Session Host > Security
  • then enable 'Require use of specific security layer for remote (RDP) connections' and select 'RDP' as Security Layer
  • then disable 'Require user authentication for remote connections by using Network Level Authentication policy'
  • finally: gpupdate /force
will see, if this works on the long run...
Michael
bzdega
Post by bzdega » Fri Jun 14, 2019 3:36 pm
hmm...
after these changes, it works but the security icon is gone in the RDP-Topbar.
Does this means, that my connection is not secure (SSL encrypted) anymore?
Michael
(690 Bytes) Downloaded 1628 times
juwagn
Post by juwagn » Fri Jun 14, 2019 8:25 pm
revert all changes you did before and follow next FAQ in Oracle Remediation part
https://terminalserviceplus.freshdesk.c ... 4000038362
Sincerely yours, JW.
bzdega
Post by bzdega » Fri Jun 14, 2019 10:24 pm
will this work also for generated client?
bzdega
Post by bzdega » Fri Jun 14, 2019 10:43 pm
there is no GPO "Encryption Oracle Remediation" in Credential Delegation on my Windows 2012 R2 Server. Or should this be set on the client?
If so, this is no solution for us. These are customer clients and we cannot change anything there nor force the customer to do so.
See attached Screenshot.
Michael
2019-06-15 00_36_07-Session - demo.proalpha.cloud - Remotedesktopverbindung.png
juwagn
Post by juwagn » Sat Jun 15, 2019 2:24 pm
it is server side setting and it should be there on Windows 2012 R2 Server
If not, upgrade your Windows system firstly and install all missed patches.
