Hi folks,
Can anyone answer whether or not TSPlus is affected by the Windows Dynamic Fair Share Scheduling (DFSS) for network and disk.
I have tested DFSS for CPU and by default, this appears to be off, which is fine as that's what I need.
However, I've read that by default the network/disk scheduling is set to be enabled on Server 2012/2016. There are no registry keys present to check these. I suspect they would appear if I installed the RDSH role, but since I'm running TSPlus, I don't plan on doing that!
Windows Fair Share
Re: Windows Fair Share
PowerShell:
=0 is disabling, =1 enabling.
$temp = (gwmi win32_terminalservicesetting -N "root\cimv2\terminalservices")
$temp.enableDFSS = 0
$temp.put()
$temp.enableDFSS = 1
$temp.put()
$temp.enableDiskFSS = 0
$temp.put()
$temp.enableDiskFSS = 1
$temp.put()
$temp.enableNetworkFSS = 0
$temp.put()
$temp.enableNetworkFSS = 1
$temp.put()
$temp.put()
$temp.put()
$temp.put()
$temp.put()
$temp.put()
$temp.put()
