RemoteApp not launching from Web Portal & "Per Machine" Connection install
H.Silva
Post by H.Silva » Wed Apr 24, 2019 9:44 pm
I have my TSPlus on W2016 Server and it works with the Setup-ConnectionClient.exe when it's installed by the client.
We are deploying machines to the field that will use GPO for lockdown and will also generate profiles after the user logs in the first time using a VPN Direct Access technology.
Because of this, I would like to try and move away from having to install the Setup-ConnectionClient.exe per user and would like to know if this can be installed "Per Machine".
While wanting to achieve this, I tried launching RemoteApp from the Web Portal (we use Chrome and it's updated as well)... but all I get is a spinning cursor when I click on the log on button. Please know, the Client generated and installed on PC runs fine. The HTML5 portion also runs fine. but the RemoteApp through the Web Portal does not.
