I get this error:
"öffnen der Datei remote nicht möglich oder es wird kein generierter Client verwendet."
when trying to start GoogleEarth on the remote client using .kml as an extension.
TS-Plus Server: 11.60.10.28
UP: V3
True, I use the native RDP-client on W7 pro.
Shellversion: 6.3.9600
Protocol 8.1 supported
Then I create a client on the TS-Plus-Server and copy it to the W7-machine.
Now there is NO PROGRAM to run a .connect file!
- This used to work with the native client!
- How to run a .connect-file?
- There may be a different cause?
Thanks a lot
Auf Client öffnen - open on Remote Client
Re: Auf Client öffnen - open on Remote Client
Ok Thank you indeed
There is a WindowsClient directory in the Clients directory of the latest server-installation.
Just copied this - and it works again.
Cheers, very happy
Cheers, very happy
