Alt+Tab
Re: Alt+Tab
This option is available in the display tab of the client generator.
Re: Alt+Tab
Is there any way of having this fixxed as a Session Preference instead of having to change X users by making them a new client?
Re: Alt+Tab
Unfortunately this setting is set on client side only. You will need to generate a new connection client for your users or use this procedure to edit the settings of existing client to add manually the -alttab 0 switch as shown here : https://docs.dl-files.com/tsplus/edit-d ... ted-client
