After upgrading to version 11.60.10.5
Users who use the Floating Pane when they click the published explorer.exe application, are automatically loading the Remote Desktop.
This can not be released.
Are any new configurations necessary for this not to happen?
Explorer.exe Opening Terminal Server Screen
Re: Explorer.exe Opening Terminal Server Screen
Seems 11.60.10.5 has some major issues and should have never been released
Yes, some other problems are bothering me.
Do you know how to perform downgrade to 11.50?
Thank you.
Thank you.
I wish I did because I would be doing that right now... instead I have a system that is useless
