Generated client on Windows 10
bzdega
Post by bzdega » Tue Nov 14, 2017 4:44 pm
the generated client starts with different resolution on Windows 7 and Windows 10. On Windows 7 i get a fullscreen rdp window which is smart-resizable, on Windows 10 i only get a window with 1536x822 pixels and it is not smart-resizable.
Is this a know issue on Windows 10?
regard
Michael
bzdega
Re: Generated client on Windows 10
Post by bzdega » Tue Nov 14, 2017 5:05 pm
HI,
i figured out, that this is not about Windows 7 or 10, it is about the client generator. I have tried an older version (before 10.50) and it gave me a fullscreen desktop which is smart-resizable.
I think there is a bug in the newer client generator which comes with 10.50.
Can you please check this?
regards
Michael
bzdega
Post by bzdega » Fri Nov 24, 2017 9:10 am
Problem solved.
I have created new clients with the actual version of TSPlus. Then i cleaned the RDP-Settings (link to path of gerenated.exe /clean). After these steps, and setting the fullscreen option (in the client genrator) to 2, my TSPlus desktops opens again in Fullscreen like before.
