Dear all,
when using the RemoteAppClient from remoteapp2.html or using html5 then
themes are enabled, but when generating an RemoteAppClient with
Portable Client Generator then themes are always disabled.
-> how to enable themes with Portable Client Generator ?
When generating a Client, even if "Sound" is not enabled, sounds are always on.
-> how to disable sounds ?
For html5 and RemoteApp2.html there is no option to disable sounds.
-> how to do this ?
For RemoteApp2.html and html5 it seems that even I enter a value for Domain
in Web Portal Settings (while not showing domain field) this value is not
used to enrich the entered login with the domain.
-> is this intendet this way ?
All testet with current Version of TSplus on Windows 7 as Server
with Windows 7 and Windows 10 as client.
Has anyone found the same problems or have i missed something ?
regards
Thomas
