Any UserName and password could be enter
kit.cheung
Post by kit.cheung » Mon Mar 14, 2016 1:58 am
I am not sure what's my configuration problem? I bought the license and setup correct, and other application is workable.
And then, we try to input the invalid username or password. We found that we could entry the system again.
Could you share me hints how to configure it? Thanks.
Re: Any UserName and password could be enter
Post by admin » Mon Mar 14, 2016 11:30 am
Make sure you did not activate gateway portal feature or the web credentials and that you entered the correct domain name in web portal preference tile of the admin tool.
http://www.terminalserviceplus.com/docs/web-credentials
http://www.terminalserviceplus.com/docs ... eway-users
kit.cheung
Post by kit.cheung » Tue Mar 15, 2016 3:39 am
Thanks for your reply, but your solution is not working well again.
I did not activate gateway portal feature ,and the web credentials.
And I input any Domain Name, the result is same.
[I remember that the old version is working well, but I am upgrade the latest version already.]
kit.cheung
Post by kit.cheung » Fri Mar 18, 2016 2:34 am
Problem solved... Thanks for help...
Barton
Post by Barton » Fri Mar 18, 2016 5:12 pm
kit.cheung wrote:Problem solved... Thanks for help...
How? Please!
