I have a Client Server application that requires the name of the client host name to pull the correct configuration from a database. Is there an API or SDK that I can use to get this information within the application? Or is it possible to include the host name in the command line?
I have seen a .Net Library called Cassia that works with MS Remote App, using the TS API, will this API / Library work with TSPlus?
Client Sever App Requires Client Computer Name
Re: Client Sever App Requires Client Computer Name
Simple. The client host name within a session is provided by the environment variable %CLIENTNAME%
The better answer is that they have to update their remote app. This can be done from the microsoft website or from optional windows update 2830477
