I am currently evaluating TSplus and installed it on a Win7 Pro x64 machine.
In application control I configured the "FloatingPanel" and some applications for the users.
That all works quite nicely so far, but I have one big problem:
When the users (connected with seemless client) minimize an application window, it cannot be restored again because it is not visible anywhere.
How can this be solved?
Regards
Dennis
seemless mode: minimized applications invisible
Re: seemless mode: minimized applications invisible
This is a resolution or taskbar issue maybe. If your server was installed with Windows seven enterprise/ultimate or 2008 you could have used RemoteApp which has better application minimizing support.
TSplus support team
TSplus support team
I am aware that this happens w/ SEAMLESS mode. I use REMOTE APP and had no issues until the most recent update. With the update my REMOTE APP now disappears when minimized. Any help??
