Missing indexonlyinside.html,
johndavies
Re: Missing indexonlyinside.html,
Post by johndavies » Mon May 13, 2013 12:36 pm
I recommend you to update your version of TSplus using this link : http://tsplus.net/UpdateRelease.exe
A reboot will be required as well as a regeneration of your connection clients.
TSPlus support team
