How to temporarily disable TSPlus services
jradigan
Post by jradigan » Wed Mar 06, 2013 6:10 pm
Can anyone tell me how to temporarily disable TSPlus? What Windows services are associated with the product?
I'd like to be able to totally stop the operation of TSPlus and restart it without rebooting i.e. stop its services, not just disable login.
Re: How to temporarily disable TSPlus services
Post by admin » Sun Mar 10, 2013 8:36 pm
TSplus service is listed as : "TSplus Application Publishing Service APS" you can restart it if you want.
jradigan
Post by jradigan » Tue Mar 12, 2013 2:34 pm
I am still able to make a connection with that service stopped. There must be another service that needs to be stopped?
Post by admin » Fri Mar 15, 2013 10:48 am
if you just need to disable remote access you can check the "disable remote access" box in the admin tool.
