TS Plus and NComputing L300
mgosx
Post by mgosx » Thu Nov 29, 2012 7:51 am
I've installed TS Plus last night to test it as an alternative to our windows 2003 Terminal server.
I've installed it on a WinXP and I can use 3 rep-sessions at the same time.
Today at the office I started a thin client / zero client from NComputing which uses RDP too.
The client shows the logon-screen but after clicking ok it shows his start-screen.
The user did not login in.
Do you know what's going wrong or do I have to setup something different?
Regards Mark
Re: TS Plus and NComputing L300
Post by admin » Thu Nov 29, 2012 3:54 pm
First of all if you can logon simultaneously and remotely on a Windows XP pro server using TSplus means that everything is fine on server side. A brand new thin client might require some network configuration to be set up before you can use it properly. Any thin client should work fine with TSplus, as long as they have a RDP 5 or RDP 6 client.
TSplus support team
